What is the minimum water content loading for electrostatic coalescer? I have heard that it should be 10%?
Water Loading For Coalescer
Posted 19 March 2013 - 03:30 AM
Posted 19 March 2013 - 03:59 AM
The inlet crude oil stream I have has very high density and therefore this heavy fluid will be mixed with light crude to a ratio that the density of the mixed fluids is no less than API. water cut is 50%.
Mixed fluid handling capacity = 150,500 bpd
light crude for mixing = 5,000 bpd
formation water = 2,750 bpd
fluid to FPSO density = Minimum 16 API
my crude BS&W specification should be less than 0.5% V
How can I attain that?
It is not possible to obtain it in 3 phase separator and therefore can I use electrostatic coalescer to achieve the outlet water content of 0.5%.
Thank you very much
Posted 19 March 2013 - 04:41 AM
I would like to notify that there is no need to look into this topic as I have entered some wrong values. I don't know how to delete the thread.
Posted 19 July 2014 - 10:34 AM
you API gravity is too low ans yes for such API crude
