The hysys biodiesel library contained triolein as an oil so make sure you have that package added and active so you can check for other oils and components from there. If you do not have access to the oils then you need to create within the program by knowing the structure and physical properties.
The list you provided looks like a list of the fatty acid chain lengths and the relative composition. 3 of these acid chains would be part of 1 triglyceride molecule and the way of presenting the information on the triglycerides is in the form of percentage of fatty acid chain lengths. It is not the actual triglyceride that you need to be using in your reaction. The fatty chain content can be interpreted as the percentage composition of the type or triglyceride. For example, palmitic and oleic acid content:
44.56% of the total number of fatty acid chains chains are 16 carbon long chains with no double bonds (C16:0, palmitic acid), this could be represented by using an approximation 45% of the oil being modeled as tripalmitin (the triglyceride of 3 palmitic acid fatty chains, C51H98O6).
39.48% of the fatty acid chains are 18 carbons long with 1 double bond (C18:1, oleic acid), which can be represented as 40% of your feed as triolein (triglyceride of 3 oleic acid chains, C57H104O6).
And so on, you can see how you build up that information in to useable components within the process.
Each triglyceride will then react within your system with 3 molecules of methanol to produce 3 molecules of the ester of the acid (biodiesel). In these two cases you would get 3 methyl oleate molecules from 1 triolein molecule (from the oleic acid chains) and 3 methyl palmate molecules from 1 tripalmitin molecule (from the palmitic acid chains).
The feed may also contain a small amount of Free fatty acids. 5-15% for palm oil if i remember correctly. These acids will not be incorporated within the triglyceride (oil) molecules and are referred to as free because of this. These produce the problems with the catalysed biodiesel production, reducing yield by reacting with the catalyst and increasing separation costs. The amount of oil would need to be adjusted to account for this so the composition of oil above would need to be reduced by the percentage of FFA within the feed. Then the free fatty acids will also need to be included within the reaction sets and those undesired side reactions also inputted as well with all the kinetic data with it, the reaction extent etc.
If you provide me with an image of your current reactions and components you are using then that might help me understand a bit more what your problem is.
Below is an images below show the reaction of 1 triglyceride molecule with methanol and also the location of the biodiesel database within the program.
I hope this helps, if you need anything clearing just ask.
Edited by ravion143, 08 April 2013 - 06:30 AM.
