Hi! I'm computing for condenser duty as part of my study. However, I'm not quite sure if what I did is correct. The two condensers in the drawing are used to partially condense a vapor using tempered water. The water also evaporates as steam as it condenses the vapor and is used for heating in other process. Could someone please check if my heat balance is correct?
I did the heat balance around the two condensers since I do not know how much is being condensed on each condenser. I also do not know the temperature of the exiting vapor after the first condenser. Though I think that most of the condensing duty is being done by the first condenser.
Condenser Heat Balance.xls 45.5KB
706 downloads
