Exchanger Condensate Line Modification
double pipe exchanger
7 replies to this topic
#1 krasygan
krasygan
  • 8 posts
Posted 15 April 2013 - 02:00 AM
i have one questine in the exchanger condensate line operation
the process diagram is like in fig 1
1. what happen if we connect the condensate like in first case
2. what happen if we connect the condensate like in the second case( most shell and tube exchanger has like case)
the steam inlet pressure is 17kg/cm2
#2 Zauberberg
Zauberberg
  • 2,728 posts
Posted 15 April 2013 - 03:09 AM
The way shown, the connection (and interdependence) of levels in the exchanger and the expansion vessel, would be lost. That defeats the purpose of process control scheme.
#3 DB Shah
DB Shah
  • 156 posts
Posted 15 April 2013 - 07:03 AM
You are equalizing drum and steam pressure, in case-1 how will you lift the condensate above the drum level (what will be the driving force)
#4 krasygan
krasygan
  • 8 posts
Posted 16 April 2013 - 12:16 AM
the driving force for the condensate  will be the drum pressure
#5 DB Shah
DB Shah
  • 156 posts
Posted 16 April 2013 - 06:58 AM
From drawing I understand that the condensate will be lifted at higher elevation than drum from exchanger, so if exchanger and drum pressure are same how will condensate travel from lower exchanger level to a height above drum height
#6 krasygan
krasygan
  • 8 posts
Posted 17 April 2013 - 01:35 AM
what u say i understand, thats why i have need clarification, the best condensate design is like in first fig or second one. or else can we reduce the riser height and not below the middle of the condensate pot. to have effective operation of the condensate
Edited by krasygan, 17 April 2013 - 02:25 AM.
#7 Zauberberg
Zauberberg
  • 2,728 posts
Posted 17 April 2013 - 01:37 AM
For the reasons mentioned above, the 2nd design is the only one that works.
#8 Art Montemayor
Posted 17 April 2013 - 01:29 PM
Krasygan:
If you truly are trying to use a double pipe as a process heater, then you are going about it in the wrong manner.  One never uses the tube side of a double pipe heat exchanger as the steam side (where condensate is formed.  One always uses the shell side for the condensing steam.
Attached is a workbook showing how condensate is removed from a thermosyphon reboiler and from a double pipe steam heater.  That is way I and many others would pipe it up.  The reason(s) for doing it this way are many.
Attached File  Condensate Removal from Steam Heaters.xlsx   99.56KB   218 downloads
