Reciprocating Pump - Acceleration Head And Suction/discharge Pressure
reciprocating acceleration acceleration head pump suction pressure discharge pressure
#1 wendanilo
wendanilo
Posted 17 April 2013 - 07:02 PM
Hello everyone, could anyone help me abou Suction/Discharge pressure in reciprocating pumps?
I know that acceleration head must be considered for NPSHa calculation, but I have doubts if it should be used to Pump Head?
I found some references in literature that only consider acceleration head in Suction Pressure, others in Suction and Discharge and there are some of them that say that is the same procedure for centrifugal pumps and acceleration head is only used for NPSHa calculation...
Does anyone know how is the correct?
Thank you!
#2 latexman
  • 1,893 posts
Posted 17 April 2013 - 07:25 PM   Best Answer
You account for acceleration losses whereever they occur, in the suction and discharge, if they are significant in the application at hand.
#3 wendanilo
wendanilo
Posted 18 April 2013 - 05:03 AM
thank you, latexman!
So, if I have no dampener, I will account for it in the suction and discharge...
#4 silkroute
silkroute
  • 12 posts
Posted 19 April 2013 - 03:16 PM
Please check into JM Campbell_handbook for gas processing. That will give you all answers of your questions.
#5 Jome128
Jome128
  • 20 posts
Posted 21 April 2013 - 01:15 AM
Acceleration head(ha) to be deducted from pressure at surface level, and
ha = L*V*n*C*SG/(2.31*Kg)
where
L=length of suction line
V=fluid velocity in suction line
n=pump speed
C=constant for pump type
K=theoretical fluid factor representing the reciprocal of the fraction of theoretical acceleration head.(K=2.5 for hot oil; 2.0 for most hydrocarbons)
SG=specific gravity of fluid.
g=gravitational constant
