Allowable Velocity For Single Phase In-Plant Gas Lines
gas velocity max velocity for gas lines single phase gas line gas line sizing norsok std for line sizing api 14e
#1 Guest_Karteek80_*
Guest_Karteek80_*
  • guestGuests
Posted 22 April 2013 - 03:22 AM
Dear Forum Members,
I am new member to this forum. I was following some discussions on the Cheresources on gas line sizing and have the following question:
I am involved in design of gas processing platforms. We are required to size single phase gas lines.
I would like to note that the case i am referring to is in-plant piping where pressure drop is not really a concern. I have followed the velocity limit as per API (about 30 m/s or 60 ft/s as recommended by API 14E). This approach is also supported by SHELL and PTS standards where it is recommended to limit gas velocities in line about 10 to 20 m/s (more conservative).
However,
1 - NORSOK standard talks about velocity limitied by equation Max Velocity = 175 * (1/density)^0.43. This is to limit noise and vibrations in gas lines. Density in kg/m3 and velocity in m/s
2 - Recently i came across the relation Max velocity = 198.5 * (density)^-0.508. This seems to be arrived based on the NORSOK equation above.
I understand the relations presented above are empherical relations.
1 - Can anybody please let me know the source of these equations?
2- If these equations are derived from a base equation, then can anybody share how it is done or guide me me where to look into?
Thanks & Warm Regards,
Karteek
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 22 April 2013 - 04:51 AM
Karteek,
NORSOK standards are basically tailored for the needs of offshore platforms where space is a premium. Wherever space is a premium the idea is to reduce the footprint of any item whether equipment or piping. Obviously if you are reducing pipe sizes for a given flow due to space being a premium you will tend to have higher pipe velocities. NORSOK does not provide the derivation of the equations which you have mentioned in your post and I think that it is not necessary to go into the background of these equations if you know that these equations are being followed by companies who follow NORSOK standards.
Having said that, a lot of veteran engineers who have been involved in piping design and sizing feel comfortable with the values that they have been using since long in their careers and do not wish to deviate from their concept of limiting velocities for a given service for a pipe. Even operating company standards have no uniformity in the limiting or maximum allowable velocities advocated by them.
On a personal note, I would never recommend a velocity of more than 120 ft/s (36 m/s) for any gas pipe. Too me, higher velocities than this put you in a zone of uncertainty and you are never quite sure of the reaction forces acting on the pipe which can lead to mechanical issues such as pipe support integrity and excessive vibrations. But again this is a personal choice of restricting the velocity to 120 ft/s based on personal experience and certainly not binding to those who have a different experience.
Maybe others who have a different opinion can share their views on the subject matter.
#3 Ajay S. Satpute
Ajay S. Satpute
  • 177 posts
Posted 23 April 2013 - 12:07 AM
Dear Karteek,
Please refer below link and the attached file.
http://engedu.ca/wp-...lae-Rev.-11.pdf
Regards.
Ajay
#4 Shivshankar
Shivshankar
  • 257 posts
Posted 23 April 2013 - 02:14 AM
Karteek,
The basic source equation is ,
Where,
  • 81a69207104f00baaabd6f84cafd15a0.png is the shear stress at the wall (N/m2)
  • 8fa14cdd754f91cc6554c9e71929cce7.png is the Fanning friction factor of the pipe
  • 9e3669d19b675bd57058fd4664205d2a.png is the fluid velocity in the pipe (m/s)
  • f7f177957cf064a93e9811df8fe65ed1.png is the density of the fluid (kg/m3)
http://www.standard..../P-CR-001r1.pdf (older Version)
http://www.thermoped...om/content/789/
http://en.wikipedia....friction_factor
If you want more information, you can contact www.standard.no . I am not sure if they will answer you but you can try.
Edited by Shivshankar, 23 April 2013 - 02:15 AM.
#5 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 24 April 2013 - 04:42 AM
Just one concern, evaluate possibility of liquid carryover if any as it will lead to erosional issues. There is an inverse relation of vapor velocity with operating pressure. It's not just the velocity but you need to be careful for DeltaP/unit length limit. Higher Delta P due to large equivivalent length will force you to cut down on velocity although estimated velocity is within the allowable norms.
Small addition to the best explainations given by other memebers. Hope it helps you.
#6 Guest_Karteek80_*
Guest_Karteek80_*
  • guestGuests
Posted 24 April 2013 - 11:44 PM
Dear Forum members,
Thank you everybody for sharing your knowledge on the subject.
The derivation for erosional velocity based on the pipe shear and fluid properties arrives at the factor SQRT (1 / density). This is also supported by sites and papers (referenced in above responses) where the erosional velocity derivation based on pipe properties (shear) and fluid properties (velocity) is explained. Normally, this is associated with two phase flow or gas flow associated with solid particles (like sand) and not for single phase gas lines.
The formula mentioned in NORSOK standard (edition 2006, which i refered to in my earlier post) is for single phase gas lines and states that the limit is based on noise and vibration criteria. The factor (1/density)^ 0.43 seems to be empherical rather than derived based on the equations.
In my opinion, the velocities based on API and old NORSOK standards (edition 1999) seem to be conservative. The new empherical relations help in optimizing the pipe sizes (by allowing higher velocities) and have been arrived at based on experience. Hence, for sizing the single phase gas lines as long as the pressure drop criteria is met and the mechanical design (like pipe supports etc...) takes into account the reaction forces due to higher velocities, the lines can be sized with velocities higher than recommneded tradiationally by standards.
Karteek
Edited by Karteek80, 24 April 2013 - 11:44 PM.
