Recovering Natural Gas From Ruptured Or Leaking Pipeline
#1 neel_avi
neel_avi
  • 45 posts
Posted 02 May 2013 - 03:17 AM
Dear Experts,
In case of a natural gas pipeline leak or rupture, the damaged segment is isolated by means of isolation valves and the gas is vented in order to evacuate the section.
A 36" diameter and 32 kilometer long pipeline segment has an inventory of roughly 2.0 million std m3, a huge loss finanially as well as an environmental hazard. Without venting, for a moderate leak (for a 2 inch dia leak)  the entire line gets depressurised in ~50 hrs. Manned stations are provided strategially at every 3-4 hrs travel distance along the pipeline.
Thus even if a team reaches the sectionalising valve stations which isolates the leaking line within 5 hrs the pipeline would still contain sufficient gas. I would be glad to receive some suggestions on available technologies like Carbon bed Adsorbtion, or mobile compressor units to recover the balance gas. For an instance if I can imagine that we could bring in mobile compressors which have to work under variable suction pressures (may be consecutive cut-ins of compressors at different pr levels).
Or is it a utopian concept? I contacted a couple of compressor manufacturers and GL noble denton for their technologies. However, havent heard from them since one month even after a couple of request mails!!
Any inputs like some proven technology providers, vendors or initiatives for similar services would be highly appreciated. It would help me start a feasibility report.
Avijit
Edited by neel_avi, 02 May 2013 - 03:29 AM.
#2 Bobby Strain
Posted 02 May 2013 - 10:24 AM
Spend your effort on eliminating leaks.
#3 neel_avi
neel_avi
  • 45 posts
Posted 02 May 2013 - 11:49 PM
Mr. Strain,
thanks for your advice. I should let you know that we definitely take up Inline Line Inspection/ MFL plans at definite intervals and do have regular survey teams from leak detection teams and assigned line walkers.
However, as you are aware 65-70% of the line ruptures or damages are caused by third party intervention. These leaks are not minor and can result into gross losses.
I wanted some ideas on those accidental aspects from experts who might be thinking in that line.
Regards to you
Avijit
