Data Sheet.JPG 54.03KB
59 downloads
Dibujo.JPG 42.26KB
61 downloads
My concern is There is a 8" valve installed that controls AGO and return it to the AtmosphericTower...To have it out of service means a lost in production, so it is a very critical valve.
This valve is a 8" Fisher ET with CAVIII trim and has a bypass line for maintenance purposes.
Even though it has a bypass line, this control valve can't be removed for its regular maintenance routine because the bypass valve fails all the time, I mean, the vibration in the bypass line raises as the bypass valve opens and the control valve closes, and most of the time big and unstoppable leakages start from the packing flange, having then a hazardous and operational situation. It is not a spare part issue, the bypass valve has been well packed all the time.
I´m attaching the control valve data sheet and a P&ID extract to see the arrangement.
I want to know how can I approach this problem ir order to have a reliable bypass valve.
I have thought about reducing velocity upstream in the bypass before the valve, or to have a bypass valve with the same characteristic of the control valve. But of course these are thoughts, I want to support my choice based in good practices and analysis.
Is there a ISA or API standard to help designing a bypass line? Any literature?
Thank You
