Separation Processes For Acetic Acid And Water Separation
moisture content removal from acetic acid separation process for acetic acetic acid and water water removal from acetic aci decrese water content in acet acetic acid and water separat separation process
#1 jogender
jogender
  • 8 posts
Posted 22 May 2013 - 03:47 AM
hello,
    I am 3rd year Chemical Engineering student, I am working on a project to remove water content from aq. Acetic acid. Please tell me what are the separation processes available for their separation.
Details are as follows:
Flow rate of aq. acetic acid = 250Kg/hr
Initial Water content = 5%
Desired water content <= 2%
Temperature not to exceed 90 degree Celcius.
Please help me out its urgent.
  • 6,729 posts
Posted 22 May 2013 - 06:27 AM
http://www.google.co...iw=1108&bih=592
Did you try Google?
#3 jogender
jogender
  • 8 posts
Posted 22 May 2013 - 10:41 AM
@Breizh  Thanxs for reply :)
Yes!! I tried Google but it shows results for distillation of dilute solutions, but mine is 95% conc. If I use progressive distillation then it won't be economical. Can it be separated by some other means?
