Difference Between Level Transmitters And Differential Pressure Transm
level & dp transmitters
#1 harshchem55
harshchem55
  • 12 posts
Posted 29 May 2013 - 08:49 AM
What is the principle difference in operation and selection guide for choosing level and differential pressure transmitter. Do we provide Differential pressure transmitter only for vacuum vessels. Please advice.
#2 mansari
mansari
  • Store Customers
  • 46 posts
Posted 29 May 2013 - 10:35 AM
Differential pressure measurement is one of the techniques for level determination. The transmitter has two connections, Low Pressure or LP, taken from top of the vessel (essentially above the maximum possible level) and High Pressure or HP, taken from the bottom. Since head (pressure exterted by the liquid on HP side) of any liquid can be converted into height if density of the liquid is known. For example, 1 psi is translated into a height of 2.31 feel for water.
Differential pressure measurement can be adopted for level measurement of stable, non agressive liquids. This is not suitable for highly corrosive, volatile  (like Hydrochloric Acid) and liquids at their saturation (like ammonia, vinyl chloride etc) because of risk of condensation of vapors in the LP side, giving an erraneous reading
No, this technique can also be applied for pressurized vessels also
#3 breizh
  • 6,827 posts
Posted 30 May 2013 - 01:20 AM
Harshchem 55
Consider this resource ,it should help you to support your query .
Hope this helps
