dtmgo1,
You mentioned in your last post: "...i like that he sticks to the topic..." but appears you yourself don't like to stick to your own topic. I am wodering if you think you know the response of your query better than everyone in this forum why do you ask it here. Unfortunately forum admin (or if somone else did i don't know) would select your answer to your own query as best answer on this topic!.
However i responded to your statements wouldn't any relation to my viewpoints submitted as reply to your query, in red color as follows:
dtmgo1,
The first part of my reply is mostly related to your query and you didn't submit your viewpoint about it...
And yes, if BDV doesn't work and most inventory would be in liquid phase the PSV might be activated before vessel failure but because the vessel pressure would remain constant at design pressure (actually relieving pressure), if pool fire does continue, it takes no long time having all inventory in gas phase due to liquid vaporization and at that time the vessel would fail due to very high skin temperature will lead to passing allowable stress at corresponding vessel pressure.
THE ORIFICE OF EITHER THE PSV OR THE DEPRESSURIZATION ORIFICE (BLOWDOWN IS FOR LIQUIDS, DEPRESSURIZATION FOR GASES) DOES NOT DETERMINE THE LOAD. THE LOAD IS DETERMINED BY THE RATE OF VAPORIZATION.
Where did i mention the PSV/BDV orifice area determines the relief load? Of course what would determine the relief load for a vessel engulfed in a pool fire and having liquid inventory is liquid vaporization rate, but on the other hand for example if we would face with an existing PSV we can determine its maximum capability in relieving viewpoint.
JUST TO CLARIFY, THE QUESTION IN THIS THREAD IS NOT WHETHER THE PSV OR BDV ORIFICE AREA IS LARGER.
Where did i mention a statement to force you to submit above clarification?
THE RATE OF VAPORIZATION IS A FUNCTION OF MASS LATENT HEAT OF VAPORIZATION, WETTED AREA AND FIRE HEAT TRANSFER. PRESSURE DURING A FIRE IS CAUSED BY THE RELATION BETWEEN THE FIXED VOLUME VESSEL, AND THE VOLUMES OF GAS GENERATED BY THE FIRE, AND THE VOLUMES OF GAS ESCAPING THROUGH THE ORIFICE.
Obvious statements just show you know about the mechanism of liquid vaporization inside a vessel in fire case. It is very well.
HAVE YOU NOTICED HOW LONG IT TAKES TO BOIL OFF LIQUIDS IN A PRESSURE COOKER WITH A BURNER UNDER IT? IT CAN EVEN TAKE HOURS. IT IS NOT A SHORT PERIOD OF TIME. Where did i mention in this regard other than "no long time"? Obviously it doesn't mean short period. Of course latent heat value, amount of the liquid,...are among the parameters would determine the time of no liquid situation. ONE OF THE FUNCTIONS OF THE PSV FOR FIRE IS TO GIVE TIME TO THE FACILITY IN CASE OF THE EMERGENCY BEFORE THE VESSEL FAILS, BECAUSE A VESSEL FAILING ENTAILS MANY MORE SERIOUS HAZARD POTENTIAL THAN THE POOL FIRE THAT MAY CAUSE IT TO FAIL. SOME TIME TO EVACUATE, SHUT DOWN, ISOLATE, ALARM, ETC. IS PRECIOUS.
Again obvious statements...........................[same as above]
JUST FOR THE RECORD AND TO STATE A TRUISM, BY LOAD I MEAN MASS FLOW, E.G. KG/HR OF VAPOUR.
DTMGO1
Edited by fallah, 04 June 2013 - 02:55 PM.
