Dear all,
i am not much more aware about flushing oil requirement in system.if we don't provide flushing oil in system what kind of effect occur in system? pls give me reasonable reason.
Thanks & Regards
PRANAV
Posted 07 June 2013 - 01:14 AM
Dear all,
Thanks & Regards
PRANAV
Posted 07 June 2013 - 03:02 AM
Dear pranav
Also you must give a clue about the process fluid.
M.Ali
Posted 07 June 2013 - 03:12 AM
Dear m.ali,
i generally ask for flushing oil requirement in system (e.g. Instruments, pumps, instrument pipes, etc.) & if we don't provide flushing oil in system what kind of effect occur in system.
pranav
Posted 25 December 2013 - 10:01 AM
Flushing oil is used for
a) Flushing of equipments(pumps,heat exchangers,filters,Process lines) which are in congealing service for taking them for maintenance/any other work
b)Purging of the instrument which are in congealing service to avoid clogging of the leads/sensing probe of the instruments(eg LG/LT/PT/FT)
c)Start Up of some of the Process units
Normally Diesel is used.However depending on pressure/temp of congealing service VGO may be used.
![]() Flushing ProceduresStarted by Guest_sparsha_* , 27 Oct 2014 |
Flushing Of Pipe LinesStarted by Guest_Alphy_* , 17 Sep 2014 |
![]() Determining Flushing Flow For Prv Pilot-OperatedStarted by Guest_barbieros_* , 19 Nov 2013 |
Throughput Of Compressed Air Required For Pipeline FlushingStarted by Guest_greengeek_* , 17 Sep 2013 |
Flushing After Shut DownStarted by Guest_A mukherjee_* , 25 Dec 2010 |
