Cooling Tower Capacity & Duty
cooling tower
10 replies to this topic
#1 paraschemix
paraschemix
  • 11 posts
Posted 11 June 2013 - 05:19 AM
Dear sir/madam,
We are in the process of calculating cooling tower duty. Our question is this.
Whether we have to consider cooling tower capacity same as that of cooling tower circulating pump capacity or we should omit the flow rates of SSF (side stream filter : CW pump --> SSF --> CT basin) and blowdown ?
  • 6,937 posts
Posted 11 June 2013 - 05:30 AM
Consider reading this document to support your query .
#3 mansari
mansari
  • Store Customers
  • 46 posts
Posted 11 June 2013 - 06:47 AM   Best Answer
The file attached by Breizh is an excellent document on thermal design of cooling tower and covers all the key elements related to cooling tower design, in detail.
To answer your question, Cooling tower capacity is the flow rate circulating through the tower. Whenever you determine L/G (an important parameter for tower performance calculations), L (water flow rate) is the flow passing through the tower packing and in contact with incoming air "G".
Sidestream filters normally draw 3-5% of the pump discharge (cold water) and return filtered water back to basin, bypassing the tower packing, therefore this flow remains in closed circulation and does not come into main cooling water heat and mass balance and its hydraulic loading "gpm/ft2"
Tower capacity is defined on the based of process cooling requirements, converted into water flow at a given temperature difference (range) specified by the vendor of the cooling tower. Flow requirement for side stream filters is specified separately (based on maximum allowable suspended solids) and this flow is added to the pump capacities, over and above the main stream recirculation.
Blowdown is also a function of water chemistry and allowable cycles of concentration, not part of the tower recirculation. Tower capacity is the flow rate of water measured at  cooling water main supply or return pipe, to or from the process plant respectively
#4 Venkat Subramanian_32163
  • 3 posts
Posted 21 June 2013 - 09:25 AM
Attached File  TOWER PERFORMANCE VER4.xlsm   807.65KB   461 downloadsThe attached xl file will help in estimating the cooling tower capability. There could be VBA incompatibility. If so this can be rectified and shared again.
#5 mansari
mansari
  • Store Customers
  • 46 posts
Posted 21 June 2013 - 10:29 AM
Excellent worksheet Mr. Subramnian.
#6 paraschemix
paraschemix
  • 11 posts
Posted 23 June 2013 - 11:14 PM
Thank you Mr.Breizh, Mr.Mansari and Mr.Venkat Subramanian. It will help me a lot in understanding of Cooling tower. :)
#7 paraschemix
paraschemix
  • 11 posts
Posted 09 July 2013 - 12:02 AM
Dear sirs,
I am working out on cooling tower basin calculation. I understand that the basin dimensions are based on the number of cells in CT, its dimension and how it is aligned.
Now,
1. I am in searching for preliminary cooling tower basin volume and dimension.
2. Also for designing pump pits associated with it.
Any thumb rules..?
Procedures..?
#8 breizh
  • 6,937 posts
Posted 09 July 2013 - 12:51 AM
http://www.cheresour...ng-tower-basin/
Consider this resource ( SPX .pdf) , you should find guidance.
Edited by breizh, 09 July 2013 - 12:52 AM.
#9 Venkat Subramanian_32163
  • 3 posts
Posted 15 July 2013 - 06:56 AM
Cooling Tower Design Norms Typical:
Water loading = 5000 - 13000 kg/h m2
Air loading = 6500 - 9000 kg/h m2
L/G ratio = 0,75 - 1,5
Approach = 3 - 5 °C
Tower operating = 80% - 120% of the design
Fan pressure drop < 5 cm
Fan blades pitch =  3° (Summer +3°, Winter - 3°)
Air velocity = 1,5 - 2,0 m/s (1,2 - 1,8 natural-draft)
Design WBT = avg. June-September (<5% exceeded)
Minimum contact = 4900 - 7300 kg/(hr)(m2 ground area)
Nd (KaV/L) = 0,5 - 2,5
Drift losses
old type = < 0,2 % circulating rate
new = < 0,02 % circulating rate
Air/water contact
splash fill = 2 - 3 m2 surface per m3 fill
film = >60 m2 surface per m3 fill
lCooling Tower Base Area required: 1Million Calories Heat Load requires 3.0-3.5m
#10 Venkat Subramanian_32163
  • 3 posts
Posted 15 July 2013 - 06:58 AM
Procedure for CT acceptance: ATC 105 specified by CTI.
Typically evaluates nd=number of diffusion units= KaV/L.
#11 slmn
slmn
  • 7 posts
Posted 01 January 2014 - 11:52 AM
thanks mr venkat
please upload the full description of the file if you have
