I am searching for any pipe line sizing criteria (for gases) for sizing the meter run.
As per API 14 E the maximum velocity for single phase gas lines is to be considered as 60 ft/s. However this limit can be exceeded if there is no noise problem. Most companies put cap on the maximum design / operating velocities in gas lines to be under 60 ft/s.
What about the meter run piping sizing? I have a problem at hand - the natural gas pipeline is 14" and it is reduced to 8" for meter run. After meter run it is increased to 10" and then further increased to 16".
If I want to suggest what is the maximum flow rate load the pipeline system can handle, should I check for the maximum flow rate at which velocity in 8" segment approaches 60 ft/s? or is there any relaxation for meter run piping??
Are there any guidelines??
Please do share with me.
Thanks and Regards,
Muni Shankar
