Enthalpy-Concentration Diagram
#1 lohiacp
lohiacp
  • 15 posts
Posted 14 June 2013 - 01:12 AM
Where can I get an enthalpy-concentration diagram for methanol-water system at 1 atm? I have searched for it and ended up getting two different diagrams. I need it quickly to complete design of distillation column within deadline. Please help.
  • 6,760 posts
Posted 14 June 2013 - 03:46 AM
Hi
consider this resource (google)
Hope this helps
Edited by breizh, 14 June 2013 - 03:50 AM.
#3 lohiacp
lohiacp
  • 15 posts
Posted 17 June 2013 - 12:29 AM
Thank You for responding but I already downloaded it from google. The problem is that it is in FPS units and I will not be able to sit and convert every value as I have my values in SI units. Please check if you could provide the link of a chart with SI units. Or can you suggest a method for designing a packed column where I would not require the usage of this diagram?
#4 breizh
  • 6,760 posts
Posted 17 June 2013 - 01:01 AM
Are you kidding ?  from cal/gm to KJ/kg  should not be so complicated : * 4.1868 .
For the method , refer to your textbook (Ponchon & Savarit method) .
#5 lohiacp
lohiacp
  • 15 posts
Posted 17 June 2013 - 02:50 AM
I did not mean it that way. I would also have to convert mass fractions into mole fractions for each value. It is equivalent to drawing a new diagram.
