Storage Tank For Hcl
#1 sajju
sajju
  • 37 posts
Posted 15 June 2013 - 05:53 AM
hello
can any one suggest what is the Material of construction used for 36%HCL and 28%HCL of capacity 3000gal
thank you
#2 mansari
mansari
  • Store Customers
  • 46 posts
Posted 15 June 2013 - 06:04 AM
Rubber lined carbon steel is a good option.
#3 fallah
  • 5,019 posts
Posted 15 June 2013 - 06:09 AM
ashrath,
1-Epoxy lined steel
2-GRP lined with PP or PVC
Edited by fallah, 15 June 2013 - 06:10 AM.
#4 breizh
  • 6,751 posts
Posted 15 June 2013 - 08:53 AM
Hope this helps you out .
#5 Satyajit
Satyajit
  • 87 posts
Posted 15 June 2013 - 04:37 PM
Dear Ashrath,
                        MSRL or CSRL tanks ( rubber lined ) are not successful to resist corrosion in long run; I have seen damage of rubber layers after 3-4 years of operation; non metallic tanks are recommended. It may be difficult to fabricate  but can resist corrosion. Hypo should not be stored for a long time as it is very unstable at high temperature and loses chlorine to the atmosphere and therby reduces the strength of Hypo from 12-14% to a very low level ( based on equlibrium properties). A  sun shed is a must .
Another important point in this tank design is to minimise number of flanges as the flanges are prone to leakage; I have experinced leakages in flanges and also pinhole leakages in lines/pumps/valves very often after few years of operation. I do recommend to have a common level trolley for LG,LI/LT and level switches.
3rd point is to install a solenoid operated valve ( DCS/ESD operated) on tank filling line with a start pernissive to open and close at tank high level  for safety reason.
Kind regards,
Satyajit
#6 sajju
sajju
  • 37 posts
Posted 18 June 2013 - 03:30 AM
thakyou for your valuable suggestions
mansari,Satyajit,breizh,breizh
