Steam & Water Analysis System
Posted 19 June 2013 - 08:22 AM
Posted 19 June 2013 - 09:59 PM
I think your question is about the condensate temperature instead of steam temperature. You can not sample steam that way because the way you show to sample steam is too dangerous with that high pressure. Steam may be out the pipe at choked flow condition (sonic velocity). Even if you just sample condensate, it is not a safe way to do that because of high pressure. Of course, the condensate will reduce to 100C due to evaporation. Condensate is valuable pure water and you should let the condensate back to Boiler Feed Water System instead of discharging the condensate to a sump.
If you just want to sample some condensate, a pot design will be better to collect the condensate in a pot and vent the steam to the atmosphere from the pot and collect the remain condensate.
Posted 20 June 2013 - 01:30 AM
I would suggest you have your steam sample line go through a small exchanger using cooling water to cool down the steam to liquid, then have a regulator to reduce the pressure then a needle valve to throttle the flow. If you do not want to have a cooling water line and exchanger installed, just have the tubing coiled up and immersed in water.
Firstly if you just let it down to atmospheric pressure, some of your sample will flash off. This will evidently affect your readings. Therefore, you have to cool everything down and take the entire volume for your sample, not just those that did not flash off... It will definitely not be accurate if any of your steam sample flashed off. Cool it down to <40C, thats my best advice for a proper sampling regime.
Edited by thorium90, 20 June 2013 - 01:35 AM.
Posted 20 June 2013 - 10:24 AM
I think I couldnot explain the question exactly.
During startup, the sample cannot be analysed directly. The sample has to be drained before being analysed to remove any materials entrapped in the pipe.This drain is Discharged to the blowdown header.
My question is since the temperature and pressure is high, I want to cool down this drain before sending to sump.
Hence iam thinking of using tundish so that the pressure decreases and becomes atmospheric. I agree that steam flashes.
But if the pressure reduces to atmospheric wiill the temperature drop suddenly to 100 degc.?
Thanks for your reply in advance.
Posted 20 June 2013 - 01:34 PM
Yes, when the pressure drops to atmospheric, the temperature drops to 100C too. The additional heat is removed as heat of vaporization when the remainder of the steam flashes off.
Posted 20 June 2013 - 11:39 PM
Thankyou very much sir for clarifying my doubt..
