Absorber Design
Guest_Tan Yingyan_*
Posted 26 February 2006 - 06:30 AM
Posted 01 March 2006 - 01:24 AM
Posted 02 March 2006 - 09:54 AM
So I would rather think that suitable technolgy would be a packed colmun, or a trayed column.
The choice between a trayed column and a packed column will depend upon many parameters, including
the absolute pressure you operate at, the L and V rates, .... and fouling tendency.
Packing is specially desirable if a low pressure drop is needed. Is that the case?
Packing works best at low flow parameters, and with non-fouling mixtures.
I hope this helps. If you need more, please por=st additional information (flows aroud the unit, esp.)
Guest_Tan Ying Yan_*
Posted 15 March 2006 - 08:28 PM
Gas flow rate = 8917kmol/h
Gas temp = 80 degress celcius
Liquid flow rate = 24751kmol/h
Liquid temp = 5 degrees celcius
Pressure used = 200kPa
I think my column needs to take into account heat effects as the system is non-isothermal
Please advice on how I can go about doing it.
The diameter was calculated to be about 4.3 m. I think it is too big for me to use a packed column as
according to industrial standards, the maximum diameter for a packed column is around 2 feet.
I hope my assumption is correct and a tray column is the reasonable choice.
Posted 16 March 2006 - 06:56 AM
As for your diameter, 4.3m seems low to me, at least for V=8917kmols/hour and L=24571 kilomols/hour and 200 kPa. What vapour density do you use? What tray spacing do you use?
To account for the heat effect you'll need a thermodynamical model that does that. If they are very significant (regarding the heat capacity of the liquid flowing) you'll vaporize more.
Posted 09 August 2011 - 05:08 AM
how did u calculate the diameter using the data u have?Thank you. I have my data.
![]() Scrubber DesignStarted by Guest_nasss_* , 07 Aug 2024 |
Scrubber(Absorber) In Apsen PlusStarted by Guest_Seonwoo_* , 20 Mar 2025 |
![]() Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
