Sour Water Stripper Simulation Hysys
11 replies to this topic
#1 zetazen
zetazen
Posted 02 July 2013 - 11:35 PM
Hello every body,
i am designing a sour water stripper based on the same SWS in industry with 26 stage with installed pump around on the top stage..pump around extract liquid at 8th stage and reflux internally at top tray.
i would like to know whether my simulation is incorrect or what, but i've already conduct a shortcut distillation to make it easier to converge. now i am able to converge the shortcut, but the rigorous collumn doesn't converge at all.
here i attach the Hysys file
  • Attached File  SWS.zip   80.63KB   200 downloads
#2 mehul
mehul
  • 59 posts
Posted 09 July 2013 - 02:57 AM
dear, i have attach SWS converge file , as you are taking actual no. of stage , instead of min. of stage , if you take actual no. of stage then your tray efficiancy in simulation must be change, at 1 tray efficiency theoritical no. of stage arround 4 or5 as per shortcut distillation report.
Edited by mehul, 09 July 2013 - 02:59 AM.
#3 raneshkumar1992
raneshkumar1992
  • 8 posts
Posted 09 July 2013 - 08:37 PM
Dear Mehul,
I am also designing a sour water stripper with 26 stages. But i just dunno how to do it because the inlet properties to the distillation column is not given. Furthermore, the condition is that I must have a max flooding of 75% and max downcomer backup of 40%. Stream 16 must also have an outlet concentration of
H2S < 25ppm and NH3 < 40ppm. How do I do it. Can u simulate and converge this?? Pls help. Thank you.
Attached herewith is the HYSYS fileAttached File  Distillation 4.zip   90.04KB   95 downloads
#4 mehul
mehul
  • 59 posts
Posted 09 July 2013 - 10:31 PM
your file is created with hysys 7.3.3 is newer version for me pl. send hysys 7.2 file.
#5 raneshkumar1992
raneshkumar1992
  • 8 posts
Posted 09 July 2013 - 11:02 PM
Dear Mehul,
Attached herewith is the HYSYS file V7.2
I have managed to converged it but that is because I put some random values into Stream 14 (eg. mol fraction, pressure and molar flow) but my target is to achieve this :
Stream 8 : Temperature is 94 degree C
Conditions:
Max flooding = 75%
Max downcomer backup = 40%
Stream 16: H2S < 25ppm and NH3 < 40ppm
All the other values are correct. (Pls refer to the HYSYS before converged as the values input are all correct).
Hope u can help. Thank you.Attached File  Distillation.zip   163.88KB   79 downloads
#6 mehul
mehul
  • 59 posts
Posted 10 July 2013 - 01:15 AM
dear, i have converge with it distilation column instead of reboiled absorber and it get your desire spec.and max flooding 72% and DC back up 29%
Edited by mehul, 10 July 2013 - 01:16 AM.
#7 raneshkumar1992
raneshkumar1992
  • 8 posts
Posted 11 July 2013 - 12:15 AM
Dear Mehul,
Can i know where u see the max flooding and DC? I couldn't find the parameter.
#8 mehul
mehul
  • 59 posts
Posted 11 July 2013 - 05:51 AM
Dear,
        in tools>utility>tray sizing>performance it is for Desine case and you will checked it for rating case also.
#9 raneshkumar1992
raneshkumar1992
  • 8 posts
Posted 11 July 2013 - 06:32 PM
Dear Mehul,
Thank you for your help. I have one last problem here. When I go to tool-->utility-->tray sizing-->performance, how come my this simulation file has nothing?? I want to determine the max flooding for this simulation file as well. Hope u can help. Thanks.Attached File  Distillation 6.zip   90.47KB   48 downloads
#10 mehul
mehul
  • 59 posts
Posted 13 July 2013 - 01:04 AM
Dear,
        after converge the file , you have to go for design or rating case from tools >utility
#11 DANA-IF
DANA-IF
  • 160 posts
Posted 26 April 2014 - 02:21 AM
HI :)
Can anyone convert the simulation into HYSYS 7.1 , I really need it to understund SWS with hysys !
#12 hector.cardenas
hector.cardenas
Posted 12 January 2015 - 09:17 PM
Hello
You have  information about of sour water stripper of a good source information for make an simulation in aspen hysys.
Thanks you
