Fusible Plug Loop System
fusible plug loop system
#1 deep_the_creep
deep_the_creep
Posted 09 July 2013 - 12:53 AM
Hello everybody,
I have just started working on an oil and gas project.I need to install fusible plug loop system on a 12 meter crude oil storage tanks and i dont know how.So need your help to understand the system.I need clarity in following things:
1.Components of fusible plug loop system
2.Criteria to choose fusible plugs.
3.Instrument to detect when fusible plug melts
4.Where do i need to place fusible loop??Weather inside or outside of a tank????
  • 6,761 posts
Posted 09 July 2013 - 01:17 AM
http://www.pneumoidr...FC_2011_ENG.pdf
Consider this resource including an email address to contact the vendor, many more using Google.
Hope this helps
Edited by breizh, 09 July 2013 - 01:20 AM.
#3 Lowflo
Lowflo
  • 180 posts
Posted 09 July 2013 - 07:00 AM
Before using a fusible plug, consider the objective of your design.What are you trying to accomplish? The fusible plug is, of course, a non-reclosing device, activated only by fire. If the objective is to prevent the tank from overpressuring during a fire, then emptying it on the ground (thru the open fusible plug) is probably worse than risking tank failure.
When applied properly, fusible plugs can be used as a layer of protection during fire exposure, but understand that they're not a substitute for a relief device. that is, they don't satisfy the code requirements for a relief device. There are no pressure vessel or tank codes that recognize fusible plugs as a relief device.
