Dears,
Attached plz find the simulation file in which am trying to simulate the Thermosyphon reboiler.
In attached file I have built two cases;
For both the cases Feed inlet conditions are same only exchanger UA values are different.
Case I- This case is simulated by specifying service UA value (404273.11 kJ/Deg. C.hr) from exchanger datasheet. For this case exchanger is converged.
Case II- This case I want to simulate by using clean UA value (1212592.15 kj/Deg. C.hr) from datasheet. But for this value am not able to simulate this exchanger.
Basically this exchanger is Stabilizer Reboiler (Thermosyphon type). It is generating 0.28% of vapor from total stream in normal operation. Normal operating duty is calculated by using service UA.
I want to check the how much amount of this reboiler will generate if I use clean UA
BY KEEPING SAME STEAM & PROCESS SIDE FLOW.
Can you plz. look in to this & try to find out the way forward.
Thanks for your time,
Rajiv
Edited by NATU, 16 July 2013 - 02:34 AM.
