We have a glass lined batch reactor where a reaction between two immisscible liquid phases takes place. Current levels of agitation were deemed insufficient for sufficient droplet formation so I was exploring options to improve mixing. Tank holds ~10,000 L and has diameter 2500 mm and height ~3800 mm
The liquids are not very viscous (~10 cP) and their densities are 900 and 1200 kg/m3. The agitator has a 25 hP motor but that motor seems grossly underutilized based on current measurements.
The fluids are fast coalascing. Coalascance time is ~30 secs in lab tests. No danger of emulsion formation.
Since droplet formation is an important goal increasing the motor rpm would be one option but that seems hard to do without major changes in stuffing box, gear box etc. (currently ~100 rpm) Other goal would be to avoid layering due to density gradients by providing sufficient axial circulation.
I wanted opinions on several ideas I had:
(a) Currently it has only one top inserted beaver tail baffle. Increasing this to two or three baffles. (Spare nozzles are available) Would help? Or not much? I understand that 4-baffles is assumed to be a "fully baffled" condition but OTOH guys using glass lined reactors (where integral / welded baffles are hard to fit ) often work with single baffles.
( b )Currently both impellers are pitched blade turbines. Would changing one to a more high-shear oriented impeller help? Being glass lined equipment options are limited but vendor offers a retreat / curved blade impeller. Which I suppose would be higher shear than a PBT?
( c ) Impeller dia. is currently 1200 mm. Based on handbook correlations this seems ok for a 2500 mm dia tank.
(d) Would adding a third level of impellers on that same shaft make sense (assuming motor is ok to supply the power)? Or are three impellers too many for this height of tank i.e. ~3800 mm? If I did go for three impellers and had to choose freely between pitched blade turbines and Curved blade turbines what combination would be optimal? I was thinking a pitched blade in the middle to provide circulation (and to avoid strong axial flow too close to surface & air entrainment) and a high shear CBT at top and bottom. Does this make sense?
( e) If I do go for three impellers, what's the minimum depth from liquid surface an impeller can safely be on the shaft to not have vortexing etc.
Any other ideas? Or would having an external loop with a static mixer help? Not sure if static mixers are a recommended option for immiscible liquid reactions.
Edited by curious_cat, 26 July 2013 - 01:46 AM.
