Hi Everyone, I am currently working on a new project and I got some problems and really need your advice and help. I need to determine the capacity of a Heavy Fuel oil Tank. The Factory that will be using this tank will produce 700 tons of steam per month. I have this only as data, can you please help me to determine what calculations should I proceed with to come up with a tank capacity that will prevent the factory from running out of fuel. Another info is that the factory work 5 days per week, 24/7
Thanks a lot and hope to hear from you very soon.
Schematic:
X Litres of HFO Tank -----> Burner ------> Boiler -------> 700 tons Vapor/month
