I get totally confused. This annoys me that I have still too many questions about pumps
Is anyone could help me to fully understand the vertical type pumps?
We have following vertical types:
1. Submersible (Submerged?) pumps which is installed in the tank. The motor is out of the water. The shaft of the pump is long enough to cover the depth. The NPSHA calculation is required for this type (?)
2. Submersible? Pumps which is installed in the tank and motor is in the water. It is used to evacuation. No NPSHA calculation is need (?!)
3. Multistage vertical pump (is this the same as “in-line”?) which is out of the tank. The suction line from the tank is connected to pump suction nozzle. The NPSHA calculation is done as usual. What is the difference between this type and horizontal type? Why should we select this type instead of ordinary horizontal type to transfer liquid from the tank to destination point?
MM217
Vertical Pumps
Posted 30 July 2013 - 11:14 PM
Posted 31 July 2013 - 03:01 AM
MM 217,
The answer to the last part of your questions are as follows:
Answer: Vertical pumps have lower NPSH required than horizontal pumps.
Answer: When your tank cannot be raised any higher to give you more head, you do not want to increase pipe size
between the tank and the pump and you have insufficient NPSH required, vertical pump is the way to go.
Posted 31 July 2013 - 06:21 AM
MM 217,
Thanks edusegzy1.
Can you guide me in difference between item 1 & 2 ?
mm217
Steam On Shell Side Of A Vertical HexStarted by Guest_Lyne_* , 09 Jul 2025 |
![]() Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
![]() ![]() Reciprocating Pump Acceleration Head With Vertical Pipe LineStarted by Guest_Sansan_* , 18 Oct 2024 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
