Hypo Component In Hysys
#1 alexandremt90
alexandremt90
  • 6 posts
Posted 11 August 2013 - 09:25 PM
Hello everyone,
I'm trying to simulate a stream containing water, ethylene gycol and salt (NaCl).
To add the salt, I created a hypo component with the proprerties similar to NaCl.
As desired, when the stream vaporizes, there is no hypo component in it, but there is the formation of two liquid phases and it's not working when entering a distillation column.
Does anyone know how can I do a single liquid phase, as if the salt was soluble in or mixable with the water and ethylene glycol solution?
Thanks!
#2 equilibrium
equilibrium
  • 22 posts
Posted 13 August 2013 - 09:49 AM
You will need to use electrolytes, Na+ and Cl-.
#3 chinmaay
chinmaay
  • 6 posts
Posted 15 August 2013 - 12:19 AM
Assuming you are using Hysys or UniSim Design, with hypo component defined for NaCl, you can set phase priorities in Basis Environment----Fluid Package Property View----Phase order Tab.
You can select Primary Phase Components and also define Merge Options.
#4 bob247
bob247
Posted 29 November 2013 - 09:55 AM
How did you make the hypo componet for salt?
#5 Ajay S. Satpute
Ajay S. Satpute
  • 177 posts
Posted 01 December 2013 - 11:08 PM
NaCl is not there in hysys databank. However, it's available in Aspen Properties databank. You may use the same with Electrolyte NRTL property package.
Regards.
Ajay S. Satpute
#6 Beqs
Beqs
  • 3 posts
Posted 15 March 2014 - 11:37 AM
Hello Everyone,
I need help on hysys, i cant understand why i am having values for standard gas flow rate when i specified a complete liquid property,(water is the liquid in question), why am i having a value for standard gas flow rate? Is it not supposed to be empty?
