Flash Drum Temperature (Hydrogen)
flash temperature drum hydrogen simulation
16 replies to this topic
#1 masino
masino
  • 27 posts
Posted 12 August 2013 - 10:05 PM
Dear members
I have a question on flash drum temperature.
I attached process diagram, which is showing reactor and flash drum.
I have understand that temperature in the usual flash drum goes down when the separation happens.
.which means that flash drum feed temperature is higher than flashed vapor temperature.
However, in my simulation, 27K/G of two phase flow at 37C enter into the flash drum just right after pressure drop to 13K/G  and then flashed.
Strangely, flash temperature goes up to 40C.
I guess this is caused by some amount of HYDROGEN.
I cannot draw a clear picture of it.
Could you let me know why the temperature inside the flash drum increases???
I appreciate for your time and effort in advance
Yours
Edited by masino, 12 August 2013 - 10:06 PM.
  • 6,942 posts
Posted 12 August 2013 - 10:54 PM
This resource may help you out :
http://www2.questcon...rmo/thermo.html
#3 masino
masino
  • 27 posts
Posted 12 August 2013 - 11:08 PM
Yes
I appreciate for sharing webpages.
I will try to find method to relate the diagram to the hydrogen specific trend
Yours
#4 PingPong
PingPong
  • 1,474 posts
Posted 13 August 2013 - 07:05 AM
Probably because there is something not quite right in your simulation input, with respect to the specification of the control valve, the downstream pipe (if included) or the flash drum.
#5 thorium90
thorium90
  • 1,073 posts
Posted 13 August 2013 - 10:08 AM
Might I ask which simulation software you are using? You could post a zip file and we can take a look at it.
#6 masino
masino
  • 27 posts
Posted 13 August 2013 - 06:49 PM
I am using aspen plus
Yours
Edited by masino, 13 August 2013 - 06:53 PM.
#7 masino
masino
  • 27 posts
Posted 13 August 2013 - 06:56 PM
I am curious that small amounts of hydrogen (0.004mol%) will dramatically drop bubble points.
This will  affect the situation that I want to make it clear.
I cannot connect this bubble point dropping into the temperature increase inside the flash drum.
#8 thorium90
thorium90
  • 1,073 posts
Posted 13 August 2013 - 11:49 PM
I will be able to open aspen plus files. Do zip them up and post for further commenting.
#9 Art Montemayor
Posted 03 September 2013 - 01:37 PM
Has everybody forgotten the notoriety of Hydrogen for having a NEGATIVE Joule-Thomson coefficient?   A negative J-T coefficient indicates that the gas or vapor will HEAT UP instead of cooling down when adiabatically expanded - such as the OP indicates he is doing.
To check out the J-T coefficient value, go to the NIST thermodynamics database website and check it out.  I did, and I got a negative value.   I remember Dr. Holland saying something about this one day in Thermo class while I was awake.
http://webbook.nist....Pa*s&STUnit=N/m
I insert the attached document as a refresher in free, adiabatic expansion of a compressed gas.
Attached File  Explaining and Analyzing Joule-Thomson Expansion.pdf   89.6KB   8140 downloads
#10 curious_cat
curious_cat
  • 475 posts
Posted 04 September 2013 - 04:01 AM
Shouldn't the OP be telling us compositions? How much H2 is in there?
#11 PingPong
PingPong
  • 1,474 posts
Posted 04 September 2013 - 12:51 PM
Amount of hydrogen is very small. See message #7.
Joule-Thomson effect is here not relevant. Moreover vapor will not be pure hydrogen but will also contain vaporized liquid, so J-T coefficient of total vapor will not be negative.
However this is a mixture of gas and liquid, that flashes over the control valve and then flows into the drum.
Due to pressure drop over the control valve part of liquid vaporizes and causes therefor temperature drop of mixed phase stream.
If the drum has the same pressure as the control valve outlet there will be no further temperature drop.
If the drum has a lower pressure than the control valve outlet there will be some further temperature drop due to further vaporization.
If the drum has a higher pressure than the control valve outlet there will be a temperature increase due to some condensation.
Therefor I suspect there is an input error in the simulation.
#12 thorium90
thorium90
  • 1,073 posts
Posted 04 September 2013 - 01:26 PM
Thank you Art for pointing out the negative JT coefficient. OP has also pointed out the amount of H2. I agree with PingPong that there could be something wrong in the simulation. However the OP has elected not to continue the discussion by not posting any replies or his part of the simulation.
#13 curious_cat
curious_cat
  • 475 posts
Posted 04 September 2013 - 02:22 PM
With that low a H2 percent I doubt Joule Thomson is relevant at all.
#14 Art Montemayor
Posted 04 September 2013 - 03:19 PM
I think you guys are right.  I failed to read his last input of 0.004% H2 and only read his highlight of HYDROGEN and the name of his uploaded file.
Without a composition, no one can seriously deduce anything.
#15 masino
masino
  • 27 posts
Posted 04 September 2013 - 07:13 PM
I appreciate for your participation and valuable knowledge so that I will take a closer look into Joule-Thomson, let alone thermodynamics
I will relate the phenomenon with negative value of coefficient
P.S
I am not finding any error in simulation input even though I am not sure everything is free of errors in it at the same time.
Afterwards, I will take care of data input and make the intent and purpose of question much clearer
Yours
Edited by masino, 04 September 2013 - 07:18 PM.
#16 PingPong
PingPong
  • 1,474 posts
Posted 05 September 2013 - 04:40 AM
masimo,
In your drawing in message #1 you show a temperature of 37 oC after the control valve, correct?
And then, only a slight distance further, in the drum at 13 kg/cm2(g) the temperature increased to 40 oC.
1) What is the pressure at the control valve outlet? Is that also 13 kg/cm2(g) ? Or higher? Or lower?
2) Did you specify the same thermoset for both the control valve and the flash drum?
#17 masino
masino
  • 27 posts
Posted 06 September 2013 - 12:26 AM
file that relates to this topic is demaged while formatting.
I will check it out and then try to provide information
thank you so much for letting me know what is going on
Yours
