I am currently working on a gas plant as process design engineer.
(1) The Gas Compressor is two stage centrifugal compressor. I have designed the suction side for settle out conditions. The discharge sides have been designed for settle out pressure + 1.3 x normal differential pressure. that is the discharge and all the downstream equipment have been designed for Compressor shut-in conditions. Normal compressor dicharge pressure is 24 bara and calculated compressor shut-in condition is 37.5 barg (this is yet to be confirmed by compressor vendor)
I believe that in this case I don't need to consider "blocked outlet case" for compressor discharge PSVs, so fire case will be the only case for PSV sizing. Is my undertstanding correct?
(2) The Offgas compressor is a screw compressor. In this case the compressor discharge PSV has been designed for blocked outlet. I am assuming that 1.3 times the normal flow rate is a good assumtion for the blocked discharge case sizing. Is this assumption valid?
thanks and regards,
B-2
