Zauber:
It’s nice to hear from you. However, it seems like you’ve been challenged again in the field.
You've got a very serious and potentially expensive problem this time – as my experience would indicate. Regardless whether you have a reciprocating or a screw compressor, you can’t tolerate any of the sand particles in your analysis – no matter how small they may be. I have had that same tiger by the tail and the only method I have found to justify compressing the resultant gas is to employ wet scrubbing – lots of it. You may use the produced water, depending on its quality , quantity and local conditions. I never tried a liquid ring compressor because of the small capacities available.
I don’t know who you are dealing with as to compressor manufacturer and vendor, but I totally agree with your refusal to employ mechanical filters to produce a “clean gas”. You will wind up buying all the filter elements you can find and you still will have to put up with continuous shutdowns and filter element replacement as well as line clean-outs. You and I both know that your compressor –and its lube system – can’t tolerate any solid particles. Even “fine powdered” particles will act as emery and soon mechanically wear out all your metal-to-metal parts – such as bearings, pistons, rings, valves, rods, packings, etc., etc.. Gas compressors and solid particles – no matter how small – don’t mix. And any attempt to deal with the situation by applying mechanical separation is, in my opinion, a futile attempt. You are perfectly correct in not going down that path. Your vendor is simply doing what he/she has to do in protecting their product’s best interest. The compressor was not designed to handle ANY solid particles and, as such, has to be protected from these. A cartridge filter – as used in the upstream oil and gas business -is strictly designed to handle LIQUIDS and GASES – not solids. The term “filter” is a misnomer here.
However, this leaves you out on a limb. You’ve probably got a “dirty” wellhead that produces 3 phases: gas, liquid, and solids and you have to process the gas. I have employed a well oversized 3-phase separator wherein I try to bring about maximum contact between the liquid phase and the solids, making the solids go into an emulsion and precipitate at the first stage of the separator where I employ sand removal nozzles and internal spay headers. I also have employed a “wash tower” employing simple, ceramic Raschig Rings and recirculating wash water. These worked well, but eventually required clean outs. A lot of the problems involving sand particles revolve around the TYPE of basic material it is composed of. Silica is one thing, clay is another. One is abrasive, the other is sticky and difficult to handle. I always remember what my Unit Operations professor in college told me: the worse Unit Operations are the ones involving solids. And I have lived long enough to confirm it.
Are you still in Peru?
