Control Valve (Flash%)
control valve flashing
#1 masino
masino
  • 27 posts
Posted 21 August 2013 - 09:35 PM
Dear Members
I want to ask you about how to calculate the flash % when preparing control valve data sheet.
This is for Medium Pressure Steam Condensate(liquid).
Inlet pressure is 16kg/cm2(G) and pressure drop is 12kg/cm2
inlet temperature is 204.7C
this is globe valve(linear)
It is natural that pressure drop through the control valve make flash in the liquid.
I cannot estimate the flash percent.
Please let me know the criteria and procedure
Yours
#2 fallah
  • 5,019 posts
Posted 22 August 2013 - 12:35 AM
masino,
As per the conditions you submitted (204.7 C and 16 kg/cm2), appears the inlet fluid is steam not liquid condensate. Please check it again...
#3 masino
masino
  • 27 posts
Posted 22 August 2013 - 02:38 AM
16.5 kg/cm2(g) and 204.7C
this is the inlet condition
and pressure drop through globe valve is 12.0kg/cm2
#4 kabtik
kabtik
  • 43 posts
Posted 22 August 2013 - 03:34 AM
I have confirmed what Fallah said using my Mollier chart. At 204.7C and 16.5 Kg/cm2 what you have is saturated steam. With that pressure drop what you end up with is superheated steam at the same temperature if the process is isenthalpic.
#5 masino
masino
  • 27 posts
Posted 22 August 2013 - 03:56 AM
Yes I will check out my process again.
I appreciate for your comment and check out
