Developing Extension (Dll) In Vb For Hysys
Posted 23 August 2013 - 11:27 PM
Posted 24 August 2013 - 01:01 AM
sunil,
with your "handson experience in dynamic simulation in Hysys software" you should be able to contact AspenTech support for help.
They'll be more than happy to help you.
Moreover, from my (little) experience in dynamic simulation, I'd say that your task is either unuseful (hydrocyclone) or prohibitive (gas turbine).
Anyway, when you'll finish your tasks, we would be happy to see your products.
good luck!
Posted 25 August 2013 - 01:56 AM
Hi Sunil,
I will not try to judge urgency and usefulness of your work, but its true that Aspen Tech Support can help you better.
For developing Extensions for Hysys in VB, you can start with Aspen Hysys Customization guide which is available with standard Aspen Hysys Documentations.
Customization guide itself contains some common examples for how to define objects, how to use keywords etc etc.
Hope this will give you a good start.
Chinmaay
Posted 31 August 2013 - 08:25 AM
I have completed exercises given in Aspen Customization guide (Reactor Extension for Vinyl Acetate, Saturate etc), However I am strugling to write a code for dynamic Hysys mode. There are certain functions like "Postcompositionstep", "PostEnergeyStep", PostPFsolver" etc which I am not able to use effectively.
Can someone give idea or example of simple VB example with Dynamic Hysys mode?
Thanks Chinmay and Gigo for your comments.
