if it is a isothermal process (at ambient temperature) you can solve directly
1) calculate density of propane at 50 atm and operating temperature
2) multiply density (Kg/M3) by internal volume of pipeline (M3) and obtain mass of propane at 50 atm
3) calculate density of propane at 1 atm and operating temperature
4) multiply density (Kg/M3) by internal volume of pipeline (M3) and obtain mass of propane at 1 atm
5) the difference Kg propane (2) - Kg propane (4) is your number
to calculate density of propane you can use graphs, tabulated values or a software
(see NIST gov, PRODE etc.)
for a different process you need to specify the type,
also in this case you can solve with charts or tables of values (mollier etc.) or a software
Edited by marchem, 24 August 2013 - 06:37 AM.
