Hi all,
I am a recently graduated chemical engineer. I am considering applying to companies in the US in order to work there, and I have heard some talk about something called the professional engineers exam (PE), and I have seen some business cards with the letters PE written after the name. Can anyone explain this to me? In Ireland/UK/Europe we have whats called "chartered engineer", this is something to which an engineer can aspire to after a minimum of 4 years of post graduate work experience. Is the PE something similar?
Niall
Professional Engineers Exam
Started by niallmacdowell, Mar 03 2006 05:36 AM
Posted 03 March 2006 - 05:36 AM
Posted 03 March 2006 - 06:35 AM
Wikipedia contains a good article on the subject of Professional Engineer: http://en.wikipedia....sional_Engineer
By the way, 'Chartered Engineer' is used in UK and Ireland (and India). In many other EU countries there is an equivalent called 'European Engineer'
Posted 03 March 2006 - 10:47 AM
Niall:
Yes, the Professional Engineer title is pretty much the same as your Chartered Engineer title. However, where you have a national set of requirements that must be met, each of our states has somewhat different requirements and the PE title granted in one state may not be valid in another state. Many US engineers in the USA may have had to earn the PE title in more than one state.
If you work for a large engineering corporation, the PE title is helpful but it is not an absolute requirement of employment. However, to work as an independent consulting engineer and to advertise yourself as a consulting engineer, it isa requirement.
Posted 03 March 2006 - 11:26 AM
I am a registered Professional Engineer in chemical engineering in Kansas, Iowa, Missouri and Minnesota. Each State has a Board that licenses engineers. All of the testing is conducted through the ncees in conjunction with the State Boards in the USA. Their website is: www.ncees.org
Essentially, you must prove that you graduated from an accredited university in engineering. Foreign accreditation may take a little more paper work. You then take the EIT (Engineer in Training) test, which is an 8 hour 1-day test. It is multiple choice. There is a general section in the morning and then a specific section in the afternoon that I was able to chose at test time. The specific sections are based on the various engineering trades (chemical, general, mechanical, etc.). If you pass the test, you will be called an EIT. Then, you must perform under the review of a Professional Engineer for 4 years (3 if you have a Masters), at which time you can apply to take the Professional Engineers exam of your choice (chemical, mechanical, etc.). Passing tat test allows you to apply to the State (i.e. send them the license fee) and you can then call yourself an engineer in that State.
Hope that helps you.
Posted 03 March 2006 - 02:47 PM
Hi there:
Check out the NSPE web site at: NSPE.org.
Thanks,
Gordan
Thanks,
Gordan
Posted 10 March 2006 - 06:31 AM
To all who replied to my question:
Thank you for your information, obviously I am at the very early stages of my career, so all of this is very useful to me and your time is much appreciated
Niall
Niall
[Research Request] Uc Berkeley Student Seeking Process Engineers For 1Started by Guest_SangyunKim_* , 10 Jul 2025 |
![]() Pe Chemical Practice Exam QuestionsStarted by Guest_AthlonXPme_* , 31 Mar 2024 |
Aiche Ccpsc Exam, And Nfpa Cfps ExamStarted by Guest_raj shekhar_* , 23 Jul 2023 |
Aspentech Certification Exam.Started by Guest_ChinmoyBasak_* , 16 Mar 2020 |
Aspen User Certification Program - No Exam Fees In MayStarted by Guest_Pilesar_* , 30 Apr 2020 |
