- Members
- 21 posts
- 0 warning points
Posted Today, 11:06 AM
Hello everyone,
This is regarding gas turbine operation.
There is a valve called False start drain valve, which operates in case of GT startup failure & drains the liquid in combustion chamber & associated piping.
I have a case, where this valve passed when the GT was running & combustion gas leaked to atmosphere via. open tundish drum leading to a hazardous condition.
I do not have sufficient documentation such as vendor P&IDs/cause & effect charts for the system, also with no prior experience associated with a GT, I have very limited know how about this system.
With limited exposure my suggestion was to get redundancy in the system to avoid this gas leakage to drain system.
So it would be greatfull if some one can share their experience on this issue, like in a normal GT system what safeguards are in place against above mensioned scenerio, or for matter of fact anything related to this valve & false start drain system.
Also I have one particular query, what happens to the combustion gas if the GT is running & accidently trips? I guess we must have some relief facility in place, apart from this liquid drain.
thanks regards,
Varun
