if you have CO2 and water at 70 C 118.43 Bar
possibly (depending from amount of water)
you may wish to calculate the parameters for the mixture
and evaluate the fraction dissolved in water,
by the way at 70 C 118.43 Bar you are
above critical pressure and temperature for C02,
while water will be (mostly) in liquid state,
you may need to evaluate how water and CO2 interact
or decide to calculate the compressibility for CO2 only,
then you may use a EOS to calculate density / volume or
some generic correlation (if applicable)
To provide a number,
for pure CO2 density at 70 C 118.43 Bar is about 337 Kg/m3
Edited by PaoloPemi, 04 September 2013 - 09:18 AM.
