My questions is: what are the procedures/code/standard should be followed for heat exchanger tubes plugging?
Plugging Heat Exchanger Tubes
Started by sameh makhlof, Sep 12 2013 02:22 AM
Posted 12 September 2013 - 02:22 AM
Posted 12 September 2013 - 06:53 AM
I know of no standards or guidelines for plugging heat exchanger tubes. But I've had to plug a lot of them in the past.
I did what everyone else I know does: get your maintenance department to machine a stock of steel (or the appropriate alloy) tapered plugs. The angle of the taper is up to you and the machinist. I left this detail up to the experienced machinist and the plugs worked well.
