Hi. My name is Ingemar Quintero. I am working in a refinery revamp, specifically in the product storage unit for fuel oil. We are trying to define the closed drainage system for the storage tanks.
We designed 4 atmospheric storage tanks (fixed cone roof) of 433,000 Bbl (nominal capacity). Typical arrangements for a closed drain system for a storage tank consist of a drain ring connected to a main header that goes to a closed drainage drum, in this case, for heavy hydrocarbons, but, reviewing the literature, especially API 650, I haven’t find a criteria regarding the number of drain nozzles to be specified for fixed roof tanks. In fact, I found that there isn’t a clear criteria for that… http://www.cheresour...ospheric-tanks/.
Howerver, according to others typical arrangements for tanks of similar capacity we specified 4 nozzles of 6" each (4 sumps). So, the problem is that I would like to know, what are the typical operation times for tank draining procedures in refinery plants? Of course, I know this depends on the capacity of the tank, the service factor of the plant (maintenance) and the properties of the fluid. According to the proposed settlement (6 pipes of 6 "and a common header of 12"), our calculations show a drain time of almost three days for a unpumpable volume of 33,320 BBl of a fuel oil of 570 cP @ 130°F.
I also wanted to know what are the advantages or disadvantages of using water drawoff sumps or bottom drain sumps. Take into account the tank diameter (220 ft) and the capacity. With water drawoff sumps the remaining volume is large enough to drain with vacuum trucks.
Thanks.
Regards.
