Hi everyone,
I wonder if someone can help me on how to simulate the a silica gel natural gas dryer on Aspen Hysys V8, as I could not find it on the Palette and I am not experiance on Hysys simulation.
Many thanks in advance
Fouad
Posted 27 September 2013 - 12:00 PM
Hi everyone,
Fouad
Posted 27 September 2013 - 12:19 PM
I've done a number of mole sieves and silica gel beds. I typically get the silica gel or mol sieve sizing info from an in house spreadsheet calculation or from the adsorbent supplier (they will determine diameter and height of the bed, cycle times and pressure drops for the adsorption and regen cycles for you). I then use the component splitter (water as one outlet stream, dry gas as the other) with the pressure drop info. I don't believe Hysys has an actual adsorption bed unit operation, and the reactors are not really meant for a simple adsorption process. Anyone else care to chime in?
Cheers,
Posted 27 September 2013 - 01:30 PM
Thanks alot ColinR33 for your help.
Posted 27 September 2013 - 09:56 PM
Posted 29 September 2013 - 02:41 AM
Thanks a lot thorium90, I have a problem with my Aspen Adsorption it has stopped working just after opening its screen.I have to resolve this issue first.
Posted 30 September 2013 - 12:48 AM
Hi everyone,
Please can anyone has the Aspen Adsorption V8 download the below patch
''Aspen Adsorption V8 Emergency Patch 1.zip (2258 k)''
upload it to 4share web site and attach the link on this topic.
Many thanks in advance,
Fouad
Posted 30 September 2013 - 09:31 AM
