One of the new client specifications state that the "Minimum Upper Design Temperature" shall be 75C for that particular region. (Corresponding to 167 F) The existing vessels have design condition nameplates of (for example) 1910 psig @ 150 F OR 150 psig @ 150 F. This has been highlighted as a non-conformance since the vessel nameplate quotes a lower temperature than the minimum required by the company specification.
This is an existing facility and this is to be applied to ALL vessels on the facility, so of course throwing away vessels, for new ones is not possible. Re-rating vessels and getting a new ASME Set VIII Div 1 stamp may also be more troublesome than needed. I can see two possible solutions to address this non-conformance:
1.) Use Pressure Vessel codes to reduce pressure / temperature correct the design nameplate values. For eg: 1910 psig @ 150 F, may be equivalent to 1900 psig @ 167 F (or thereabouts...) This option however, will mean changing the design temperature of the vessel, which will impact a wide variety of items: PSV Set Points (& possibly sizes as well), HIPPS Valve functionality, Alarm and Set Points of the control system, design margins, blowdown calulcations...etc. For this reason, this option is not feasible.
2.) Use a calculation procedure to show that the wall thickness of the existing vessel is adequate for temperatures up to XXX F, which is far higher than 167 F and therefore no changes are necessary. There may be other criteria than wall thickness...maybe vessel stress analysis or showing that the exsiting metallurgy can withstand higher temperatures.
There is a third option, which involves using the piping specification for the facility (ASME B31.3) and using the pressure temperature correlations as per the spec...but I suspect the Vessel Engineers will have a fit if I try to justify different design conditions for a coded ASME pressure vessel using piping specs.
Any thoughts on this / suggestions as to how to work around the 'non-conformance' ?
Rush
