HI Everyone,
I need a bit of advice how to proceed with this problem. Attached is the actual situation.
To start, I would like to say I am very limited in terms of information, but nevertheless I hope to get a result hopefully.
I am storing HEAVY FUEL OIL in a tank of dimension: diameter=2.85m Height=4.80m
I am using a coil of 15m, dimaeter 1.25 inches with X number of turn to heat that HFO.
Basically, the Steam is coming from a boiler pressurized at 7 bar.
But the steam passing entering the Tank through the coil is pressurized at 2 bar. I am assuming the Inlet temperature of the steam entering will be around 150 deg but I believe I can calculate that using my Superheated Water table and extrapolate to get this temperature.
The problem is that I am a bit confused based upon these conditions, how am I going to get the maximum temperature that the HFO can be heated.
Any advice would be very helpful.
In case I miss something, please do let me know.
Cheers
Roy
