Hello all,
I have to design a new plant with PSA type adsorber system to remove CO2,Moisture content.
Feed condition:
Air flow-2000Nm3/hr
Pressure-9 bara
Temperature-40 degc
CO2-400ppm
Moisture-100% RH
Desired Outlet condition:
CO2-<1PPM
Moisture-(-)100degc dew point @ atm. pressure
Can anybody help me in designing the system?
Specially:
1.How to do depressurization line size?
2.How to determine purge flow rate?
3.We intend to depressurize the bed upto 0.3 barg(based on purge gas pressure).Is that assumption good enough?
Any reply will be highly appreciated.
Arpan
