Dear all
does have any notes or information regarding cooling of reactors using liquid nitrogen usually called cryo cooling . a process diagram of it would be helpful.
thanks in advance
smrtchemengg
Posted 09 October 2013 - 10:26 PM
Dear all
thanks in advance
smrtchemengg
Posted 09 October 2013 - 10:57 PM
What's your application? Size? Temperatures? What sort of reaction is this.
Posted 09 October 2013 - 11:16 PM
More information required. Reactions occur better at higher temperature. Even if they were exothermic, there would come a point where if it was too cold, the reaction just wouldnt happen. Some experimental reactor whose components react cryogenically?
Posted 10 October 2013 - 01:32 AM
sir
sorry for the incomplete question. my area is related to industrial services during shutdown operations. the idea is cleaning various exothermic reactors used in petrochemical industry, before cleaning the reactors have to be brought down to normal conditions.it has been found it can also be done using liquid nitrogen for quicker cooling . but i could not find any data related to it . if possible please share.
thanks
Posted 10 October 2013 - 02:08 AM
Why would you want to place undue thermal stress on the reactor by quenching it from hot temperatures to room temperatures using liquid nitrogen? That's even assuming your reactor can take that kind of low temperatures? A gradual controlled cooling is definitely the way to go and not the way you suggested.
Posted 10 October 2013 - 08:44 AM
sir
In steel industry they use a process called dry quenching especially in coke cooling section. i thought if this is used instead of traditional method in reactor cooling during shutdown, we provide a better safer environment for working and earlier cooling.
Edited by smrtchemengg, 10 October 2013 - 08:45 AM.
Posted 10 October 2013 - 09:29 AM
@thorium: That was exactly my first impression too. But it seems quite a few (reputable) companies out there advertise a similar solution.
Never used it myself though. Sounds wacky. Wonder how they deal with brittle MOCs, thermal shock, spalling, expansion etc.
http://www.airproduc...or-cooldown.htm
http://www.buchen-ic....php?id=488&L=1
http://www.halliburt...plications.page
Posted 10 October 2013 - 10:10 PM
I encountered this in the mid '80s with Shell. They used liquid nitrogen to inject into circulating gas to cool a hydrocracker. Never got to the details, 'cause I wanted nothing to do with it.
Posted 10 October 2013 - 10:45 PM
Ha! So this has been around for a while, eh? Wonder how much time it saves that makes it worth it.
How long does a hydrocracker take to cool conventionally?
Posted 11 October 2013 - 06:40 AM
thank you very much sir....(curious_cat) for the information.
any details or process diagrams is welcome. please can anyone provide the step by step safety procedure for cooling of reactor by air. the one used in petroleum industry where venting and removal of toxic substances is required. if possible please upload in pdf format.
thanks in advance.
Isenthalpic Throttling With Flashing LiquidStarted by Guest_lofarcio_* , 06 May 2022 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
