Something thats been puzlling me and is a bit outside of my experience is when you have an electric motor and a steam turbine on the same drive shaft, and the steam turbine is used for startup before for example a flue gas expander and the motor/generator take over, as is the case on an FCC power recovery train. Does the fact that you start up on the steam turbine avoid the large surge in power required to start the motor? And secondly is the motor typically sized to take the full load in the case where you just have the expander and motor with no steam turbine?
Steam Turbine And Electric Motor On Same Shaft
Started by StealthProg, Oct 11 2013 10:08 AM
No replies to this topic
Posted 11 October 2013 - 10:08 AM
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
![]() Steam Used In ReboilersStarted by Guest_aliebrahem17_* , 05 Jul 2025 |
Steam On Shell Side Of A Vertical HexStarted by Guest_Lyne_* , 09 Jul 2025 |
