Mohamed:
ColinR33 is giving some correct and experienced advice. I have undergone and experienced the pulverization of silica gel when submitted to rapid and very hot regeneration gas. By this time I would hope that the whole world knows of the propensity for silica gel to "dust" - revert to dust when subjected to attrition and bed movement. This is one of the trade offs when using silica gel. And that is mainly why I stopped using it when I obtained equal or better results from activated alumina. Silica gel was developed for purposes other than drying gases and industry has put a lot of applications on it in the last 100 years. Some of these applications go beyond its capabilities, in my opinion. Please read the attached workbook that I compiled of one of my favorite adsorption articles. I took the time and effort to make this workbook because I couldn't allow for the historical facts and data to be lost and not shared with other engineers. The pioneering application at Carthage, Texas was done 60 years ago and the results all show us that silica gel hasn't changed at all in its performance data. Note that the initial startup of the beds was done with a special "conditioning" procedure. Even at that time, it was suspected that silica gel has limitations in how hot it can be regenerated.
Like ColinR33, I also advise you to be careful in how you regenerate a fully, 100% saturated silica gel bed. If you can, it would be wise to obtain recommendations from BASF before applying heat to such a spent bed. I also believe that your plant management is making a foolish and inexperienced decision in not applying a rental heater while inspecting the existing one. Nevertheless, it is their call and they will learn from it - hopefully not too expensively.
Natural Gas Dehydration With Silica Gel 1955.xlsx 567.84KB
45 downloads
