Does the coalburn factor increase with temperature? If so, why?
Colburn J Factor Variance With Temperature
Posted 12 November 2013 - 02:10 PM
Posted 12 November 2013 - 04:17 PM
Are you by any chance referring to the Chilton and Colburn J-factor analogy in heat transfer?
Posted 13 November 2013 - 03:19 AM
Yes..the j-factor. Does it increase with temperature?
Posted 13 November 2013 - 04:45 AM
From the definition of J factor = Nu/( Re *Pr^1/3) you may find the answer , in particular considering the impact of the temperature on the viscosity !
Hope this helps
Posted 13 November 2013 - 11:21 AM
@breizh.. why dont we consider the change of other factors like density, thermal conductivity with temperature?
Posted 13 November 2013 - 08:05 PM
You need to evaluate which property is more affected by temperature change. To me it's viscosity .
Posted 13 November 2013 - 10:04 PM
@Breizh....thanks a lot
Flowing Temperature- PsvStarted by Guest_stu_* , 17 Feb 2025 |
![]() Temperature PredictionStarted by Guest_paul_ohoir_* , 10 Jan 2025 |
Fire Relief Case - Relieving TemperatureStarted by Guest_alexzo1990_* , 06 Nov 2024 |
