Currently i am working on an indirect water bath heater API 12k.
Heat duty : 6.25 MW
Burner duty: 2 x 100% with seperate forced draft fans for aspiration.
Low Nox type burner.
One vendor has offered two seperate fire tubes each mounted with a 100% duty burner to meet the spec requirements.Both the firetubes are having multiple return tubes which are manifolded at exit.
A single stack is provided common for both the gas exits.
I would like to know whether two seperate stacks are required as per API 12K , since we have two seperate gas paths.
Please help me in getting a solution based on your expertise & knowledge on silmilar heaters.
Visakh
