Steam Turbine Driven Slurry Pump In Rfcc
#1 Eric Nguyen
Eric Nguyen
  • 42 posts
Posted 29 November 2013 - 07:22 AM
we are using the HP turbine to drive slurry pump and high pressure steam exhausting from turbine is low pressure steam and  put into  LP header . By design temperature is around 160 degrees but the temperature of the LPS come from Turbine is now about 280 to 300oC. how to improve the turbine to reduce LPS temperature to 160oC. What was wrong with turbine?
#2 PingPong
PingPong
  • 1,466 posts
Posted 29 November 2013 - 01:26 PM
Nothing really wrong with the turbine.
Engineers often do not realise that this kind of relatively small turbines have a miserable efficiency, in the order of 15 - 30 %, depending on size (power).
As a consequence its outlet temperature is very high.
This sad fact is often overlooked when such turbine is added late in the process design phase, or when such turbine is added later in the plant.
#3 curious_cat
curious_cat
  • 475 posts
Posted 29 November 2013 - 02:05 PM
I'm curious what's the flow rate / head developed by this pump?
#4 Eric Nguyen
Eric Nguyen
  • 42 posts
Posted 30 November 2013 - 07:21 AM
   Rated flowrate:  769.4 m3/h
   Suction pressure: 1.7 Kg/cm2
   Discharge pressure: 12.1 Kg/cm2
   Differential head: 134 m
#5 thorium90
thorium90
  • 1,073 posts
Posted 30 November 2013 - 08:59 AM
Perhaps some more info on the turbine might help to understand more. Perhaps design parameters, current parameters, some past history or some drawings etc
