Is the possibility of reverse flow into a vessel via a relief valve a credible scenario or does a relief valve itself act as a check against reverse flow? If the relief line is connected to a common header which has other vessels which may vent flammable / toxics into it how does one normally design for this situation?
I think a downstream NRV is a strict no-no due to the possibility of a restriction. I guess a downstream rupture disk to ensure positive isolation is one option? What other options are there?
Could a pilot operated valve or a soft seating relief valve be counted upon to ensure sufficient sealing against backflow?
