Hi to everyone!!!
Many times it has been observed that people comment about improper combustion of Furnace Oil(FO) in combustion chambers. One of the primary reasons would be that air flow(primary) is not sufficient for the given feed rate of FO in combustion chamber.
The same needs to be calculated using the composition of the FO used and hence adjust the air flow rate. A lower air flow rate would cause improper combustion where as a higher rate will lead to loss of energy as flame temperature would decrease.
So here is calculation of Air required for combustion of FO in combustion chambers.
Hope you like it.
Shishir Vikash Singh
