Reciprocating Pumps
#1 dreambigger777
dreambigger777
  • 16 posts
Posted 05 December 2013 - 01:49 AM
Reciprocating pumps dont need priming while centrifugal pumps need so. Could anyone please tell me what is the reason behind this? Also how teh reciprocating pumps can work air bind while centrifugal pumps cannot? Thanks in advance :)
Edited by dreambigger777, 05 December 2013 - 01:51 AM.
#2 fallah
  • 5,019 posts
Posted 05 December 2013 - 03:03 AM
Centrifugal pumps have to be primed before starting and the suction pipe and pump casing should be filled with the handling fluid. If such pumps aren't primed and to be started, they would produce a very small pressure by handling the air with low density not to be adequate to suck the fluid through the suction pipe.
On the other hand, reciprocating pumps are positive displacement and self-priming machines and when to be started without previous priming, can be able to suck the fluid by developing pressure at downstream via positive displacement movements. Then they don't need to be primed before starting...
