Heat Of Dilution For Aqueous Nitirc Acid
#1 S.R.Shah
S.R.Shah
  • 113 posts
Posted 08 December 2013 - 02:43 AM
Hi All
I am working on design of  Aqueous nitric acid vapor condenser.
Heat of Dilution can be calculated by 1. Heat of Formation  data of Aq. Nitirc acid Solution 2. Enthalpy concentration Diagram for aq. Nitric Acid Solutions.
I could not find data of Heat of Dilution data for Aqueous Nitric Acid
Please help me in this regard
Thankins in Advance
SRShah
#2 jrtailor09
jrtailor09
  • 158 posts
Posted 08 December 2013 - 03:00 AM
Dear Shah,
I have found from internet only.
Find attahced mightbe useful.
Jatin
#3 S.R.Shah
S.R.Shah
  • 113 posts
Posted 08 December 2013 - 03:24 AM
Attached File  Heat of Dilution for Aq. Nitirc Acid.xlsx   178.69KB   123 downloads
Dear Shah,
Jatin
Dear Jatin
The same data I have downloaded  from Internate but does work for me as initial molality project concentration to 77.77%
I need Initial concentration 100% Nitric Acid.
SRShah
Edited by S.R.Shah, 08 December 2013 - 03:39 AM.
#4 fseipel
fseipel
  • 81 posts
Posted 08 December 2013 - 07:45 AM
Maximum heat occurs at 1:20 mole ratio dilution per http://nitrogen.atom...itric_acid.html -- this table may be more convenient for the application.  Are you trying to compute condenser duty or consider a scenario where tubesheet leaks cooling water into a concentrated Nitric solution?
#5 S.R.Shah
S.R.Shah
  • 113 posts
Posted 08 December 2013 - 10:33 AM
fseipel
I would like add heat of Solution after condensation of Nitric acid and water vapors in heat required for  condensation.
I shall also check tha reference
SRShah
